What about water getting in the tires and the foams soaking it up?
Searching google seems it's about a 50-50 split on people who run with or without the foams.
-Michael
slawsonb,
How large are you holes? I've drilled two holes in the tires (3/32) and it looks like the tire just sealed right back up.
-Michael
WoodiE,
Did you notice after installing the foams and glueing the tires did they not fill with air after you compress them. I tried my best but there was no way I glued the tires 100% which left enough air back in so I never needed the holes.
Does anyone know if theres foam in Hobbytheks preglued MT-tires?
I've seen some guys put small holes in the rim.What is the advantage/disadvantage of doing this?![]()
