Fuel tank,need a air vent?
Fulgor72
Italy
Hi,
I would want to know which is the solution for the Fuel tank, the cover must have one vent air inlet?
when overthrows the RR not peach more the fuel, and it is extinguished, as I can resolve the problem?
Thanks.
MONAROMAN
Sydney Australia
I vented mine thru the rubber grommet that the fuel lines run thru, just made a third hole in it for a vent line. If you cable tie the end of the vent to the rear of the chassis pointing down and extending about a 5 to 10mm below the chassis - when the RR flips the tank will be below the outlet of the vent and you will not lose fuel... mind you it sprays out nicely if you cartwheel the thing!
