huergui_team
Hello, I hope you are all very well ..
I have a 1/5 scale onroad car, and I have 2 steering servos, 1 throttle / brake servo and 1 brake servo. My radio is FUTABA 4PL
The drawback I have is the mix in the direction ...
Channel 1: Direction
Channel 2: Throttle / Brake
Channel: 3 Brake
Channel 4: Address (Slave)
What I don't understand is the configuration of the same mix:
MODE: ON (It is to activate, that would be OK)
The question comes HERE WITH THE MXMD: it has to be activated or deactivated for the address, I want the slave channel of the address (Channel 3) to copy identically everything that I configure or modify in channel 1 (Channel address that commands)
TRIM: I always have it activated because for when I modify the trim on channel 1, that is if it is copied as is to the slave channel.
Of course, thank you very much for the explanation of that MXMD command that I do not understand ...
If anyone has the same radio configured and mounted in a car with two steering servos, I appreciate your help for the best possible configuration!
Greetings
Mariano
Channel: 3 Brake
Greetings
Mariano
