G320 gearing: 19/55 or 20/54?
vafan13
Now that the baja is running again, I already want to dump the CY23 for a G320. For now will be running it stock with a Dom pipe on grass and some dirt. Do I want 19/55 or 20/54?
19/55 fella (y), always seems to be the sweet spot,
you do mean for the g320 don't ya? if you're gonna be running the old 23 then i'd run either stock 17/57 or 18/56, you could try 19/55 on the 23 though, and if yer gonna be upgrading to the g320 then you'd already have the gear set,
Thanks. And yes, for the G320.
Is the HPI red 8k clutch spring the correct one? I assume so, but the description on DDM doesn't mention the G320.
yeh i seen that the g320 isnt in the list for the 8k spring fella,
the standard spring for the g320 is either 5k or 6k, but a lot of people use the 8k,
its just personal preference to be honest,
some people like the lower engagement and some higher,
myself i prefer the 8k,
but the 8k springs will fit the clutches (y),
edit, i'm talkin about the 54mm 2 shoe clutches above (y):D
Does anyone still have a 19t pinion for sale? I'm having a heck of a time finding one.
