djmaincheese
New Member
I just bought 2 of the new gensacearespammers 4S 7200mah packs. What do you recommend I set the Charger Amp rate to? I have the venom Pro Duo 80W X 2 but it does not go above 7.0A so if i understand correctly it will charge the batteries just below 1C Correct?
Is it a decent charger or should I get something that can charge higher than 1C.
I plan on getting some 4S 9200mah packs which will probably take forever to charge no?
Thanks for your time
