Got another 5t
Boostedmk3
Rebuilding the shocks along with installing DDM springs View attachment 83026
What wt shock oil did you go with on the black springs? Did you go with higher rate of spring? Is it too stiff for pretty much stock weight?
Yea, I'll be getting a TR billet intake along with another spyder filter. I tell you what the spyder filter is great and no oil to start attracting dirt to it
I went with the TaylorRC version. Cheaper and shorter intake run. Very nice piece.
Rep732
The alchemist ☠️
Community Leader
PLUS member
Build Thread Contributor
Nj
@Boostedmk3 I went with 50wt oil and I set the preload of the front at 10mm and the rear at about 13mm. I measure from the top of the adjustment collar to the lip on the bottom of the shock that the collar would bottom out on. I like the setting and both of my 5t's run the same shock setup with no chassis slapping.
I forgot about the Taylor rc intake and it does look good, I may do it on this one.
Boostedmk3
Thanks! Did you upgrade the spring rate or kept it stock?
