razorback racing
- Reaction score
- 1
Found this to be reliable?Have done the RTV head gasket mod, been proven on pocket bikes // piston port and reed engines. There is a slight improvement in peak power, the engine feels more alive, and has a cleaner top end. Make sure surfaces are clean, place oil moist paper towels stuffed into the crank so any old gasket material scraped off sticks to them.
Place a thin coat of orange high temp gasket maker (about $8.00 or so in Auto Zone), let it dry for a minute or so to get some consistency and then let the cylinder head lay on top of the block, hand easy tight (do not squeeze out the sealant). Let it dry out to its gummy cured state, then proceed to cross tighten the head to the block. Do a heat cycle (drilling the four holes in the plastic fan cover helps), and re-tighten.
The RTV mod is a old trick, proven on 2-stroke 49cc pocket engines, and those engines do rev high sometimes into the 12 to 14k pushing an old fart like me.
