usedeqeric
I own a FS King Kong MT converted to 4wd. I don't believe the truck ever did roll freely on its own while off or running. I am fairly new to 1/5 scale gas rc. I ran Nitro trucks for 4yrs prior.
Question 1- should the truck roll freely either running or not running ?
I get gear clanging when I push the truck while not running but it will roll freely in reverse.
Also, the running and I let off the gas, the truck coasts but makes all kind of gear noise. I rebuilt both diffs when purchased new since the manuf does a poor job from the start so I know its not the diffs. I don't think the brakes are hanging up either. All I can think is the clutch but don't want to tear into it and be wrong. I did a sight check on the trans gears and the dog bones -all look ok.
Question 2 -is the FS CN 30CC engine clutch compatible with a clutch from HPI or Zenoa ?
I would like to get a better or upgraded clutch if that is the issue.
I know I am losing total power and stressing the engine.
Questions 3 - where can I get a new gasket for the exhaust at a reasonable price ?
Thank you in advance - I appreciate your input. Eric:
