(help)motor on beetle keeps moving
pep37412000
GA.
can some one please help, everytime I run my beetle I have to tighten and reset the mesh for the diff and it just will not stay tight I have to tighten the bottom screws and the top 2 screws and from the top you can see where it has moved it will run for about 10 min. and then it will grind at first I thought my diff went out but that was not the case can some one please help :(
cyclops1970
Hamilton Ontario Canada
grab small and large alloy motor mounts = no more problems
http://www.pythonmotorsports.com/fg/offroad_parts/fg_truck_parts/hop_up/truck_hopup.html
Timmahh
Bajastafarian Madnes
PLUS member
Michigan
also, its very important to use Locktite, blue or red, on the bolts and then you must let the set for 24 hrs before your run. the 24 yrs allows the locktite to dry, and hold the bolts from loosening up. I suggest the Blue locktite, as the red can be very hard to break free, and often needs to be heated to break the red free.
T
cyclops1970
T
very good point !
i forget to mention things like that because its second nature for me to use loctite on everything but plastic .
pep37412000
GA.
thanks guy's I will order that but for right now i'll get the plastic for the weekend and order the alloy ones for all three trucks in about 2 weeks if i'm gonna do one I may as well do them all, need to find someone who makes the alloy parts around here just a little bit cheaper not trying to be a cheap a** but I have to look out for the pocket :clown: seeing I have to do to more than 1:)
likansuk269
london
the other way to sort the problem is to put on a bigger layshaft gear ,which will take up the gap caused by the engine movement,i had this problem on my touring car but fixed it by doing that...
pep37412000
GA.
thanks I will also consider that also likansuk269 I see you are new here to how do you like it so far, man this is a great site
