Hitec HS 5765MH servo need help mounting them in MT
hivemind
New Member
Hello all. Like most people i have burned through two sets of the stock servos even after end points were adjusted. Was given a set of the Hitec 5765 but they are a wee bit of a different size. Has anybody done this install? And if you did what parts did you use? Ideally i wouldn't need to drill any holes and find a direct drop in bracket.
