Man I need some help here. Rovan 450LT 4WD
I just put a new top end on because I think I didnt break it in right the first time. Seemed I lost compression. New top end in and it is tight!
This time I started it and idle for about 5 minutes. Then after cool down I let it idle for 15 minutes. Then after cool down I was out and running it at most I never got above 1/2 throttle but mostly just enough to keps it running and rolling, and all of a sudden it went wide open and I could shut it down. I am pushing it into brake mode and nothing! So I quickly sent into the grass and flipped it and it tacked out and quit before I got there. I was within 3 seconds of getting to it after I flipped it. Damn thing was hauling the mail!
I pulled the body off and have noticed that the throttle servo was a full throttle. I manually moved the servo back into place and turn the radio on the the truck. after a few seconds I noticed that the servo started to glitch without touching anything. It glitched to full throttle. WTH might be the issue here?
Bad servo?
Trim on radio?
Any help and input will be appreciated.
Bad servo?
Trim on radio?
