How much fuel tanks
renox
hello guys
How much Fuel tanks must end until the motor is over ?
i talk about the Kingmotor baja 5b
Thank you for help
Hi Renox, I suspect English is not your first language, no offence.
Please insert your location.
Do you mean:
How much fuel does the tank hold?
OR
How long does one full tank typically last in 'normal use'?
You right my friend about my english
My question doesn't matter anymore
I think he is asking how long the motor lasts? Here are some answers:
-1 tank of gas lasts me about 45 mins until it runs out.
- The motor will last a long time as long as you use 91 or higher octane with 25:1 ratio. 28:1 is also good, but any leaner is going to cause more wear on your engine.
-Checking on your engine bolts and cleaning your air filter will keep your engine running a long time too.
-Maxima castor 927 is a very good oil to mix in your gas. I use it in my motocross bikes and Oneill Brothers run it in all their motors too.
I hope this helps. Let me know if I can help more.
