jackobyte
- North Wales
I know most have seen my homemade panels etc but thought i'd show you how i made them..
First i purchased sheets of 3mm Coloured Perspex (A4 size) and a sheet of 2mm Lexan (A3 Size)..
Tools i'll be using are:
Dremel with cutting blade
Large Round sanding disc and Small Sanding disc
Clamp and marker..
I cut out Cardboard into the general shapes of the Panels and window..then marked out the shapes on the Perspex sheets..
Once marked out i cut the panels out with the Dremel cutting blade..
Clamp and marker..
