How to determine the "cc" of a Rovan engine?
b.l.allen
Easy Central Oklahoma
I've got a Rovan engine that has only the "rovan" marking on it. Nothing about size. The individual that I got it from had no idea. Is there anyway to determine what the engine size is? Your input would be appreciated. Thank you.
Oh, by the way, it is a 4 bolt head, not a 2 bolt, if that helps any.
Teejay112
Got a pic of the cylinder head at all ?
Sent from my SM-N960F using Tapatalk
b.l.allen
Thanks for your input. It's much appreciated. Do you know the piston sizes as they correlate to cc's?
Teejay112
Polar_Bus
New Hampshire USA
So from what i'm gathering for engine cc bore and stroke specs :
23cc - 32cc all use the 28mm stroke crank
34cc- 36cc use the 30mm crank
latest 45cc use a 31mm crank.
