How to remove Baja 5B front wheels
Newman
New Member
Hi Guys, new to this forum. Got into some serious problem with the front wheels of my Rovan Baja 36cc. The front wheels seems to be stuck with not the slightest movement between the hex and the wheel. Unlike the rear wheels which came off easily. Should I use a hammer to knock on the hex or wheel? Rovan says both rear and front wheel are not secured by any E-clips. Any advice would be greatly appreciated.
3illmesmart
Lifetime PLUS!
PLUS member
You took the nuts off, right? They could have tightened somewhat. Try setting hub in a deep socket and tap with the handle of your hammer on the threaded end.
Pics would help.
spents
Uncle Fester👻
PLUS member
oop north
just slacken the nut on the outside mate, then thumbs on the nut and fingers on outside of the wheel and it should come loose (y) ,
might need a wiggle but should come off fairly easy,
