how to wire my toy
itlog
Winnipeg
3 servos, 2 for steering 1 for throttle
1 "y" wiring harness w/ trx connectors
1 3 wire switch, two female and one male trx plugs
1 battery pack w/ tamiya connector
Also i have a Spectrum radio w/ 2 wire switch and battery holder. Where do i use those, for the reciever????
throw away your battery holder you need a 6.0v 3000 mah 5 cell size C
depending on your vehicle you need either a flat or hump pack that will run your receiver and servos
http://cgi.ebay.com/Baja-5B-HPI-5-c...ryZ34061QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Intellect-4200m...ryZ84443QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
did you get the spectrum new? are you using the spectrum receiver?
.....our servos cant handle 7.2 direct volts unless you have a BEC...spectrums receiver needs 4.8-6.0V
On page 11 of the Spectrums manual Read the NOTE on the top of the page
Use a 6v 5 cell battery that plugs into your on/off switch, then plugs into your receivers battery plug in .
Y harness to both steering servos then plug into steering on receiver
last your throttle into your receivers throttle/brake
