- Bristol uk
we should have a" build'a'bits" thread ??Build a bits 32cc ?
Mine would look like a pile of garbage (literally) ??we should have a" build'a'bits" thread ??
uncy B?King womble you start off the festivities ?????
Yo unc ?️?uncy B?
That title is mine... and it's a 1.0 not 2.0.... just don't tell the 2.0 parts that are on it ?Womble badger 2.0?????
All the cars bouce on the rear straight ?? shocks have 0 preload and only 25wt oil? pretty light ?? need to strip down ??Your rear shocks are too hard, I'd bet all that arse bouncing put quite the shock load on the trans, keen to see what ? the bed
Still think it gears coz it has engagement on half (180) but not the other?That was a good video Dougy. You think the pin may have broke on the lay shaft?
In the vid I go through the same bends then you can hear my start reving like fek? then I get rear ended ?? thats where the ? went down? .....give me some time to wrench and we will see??I don't think it's the gears, I think it's either a pin or maybe the trans Case feked itself and the meshing is too tight. Those stock gears are tough
Keen to see the pix ?All the cars bouce on the rear straight ?? shocks have 0 preload and only 25wt oil? pretty light ?? need to strip down ??
