yannkibongui.com
- Paris, France
HPI Baja 5B "TARMAC" or DIY Freefly Tero
Hi all, I will present here my "little modified" baja 5B
I'm french so excuse my english...
I am director and cameraman, I have a big shoot in two months on open road and race track for a Japanese car customizer. I want to make stabilised close to the ground shots and the simplest solution is to rent or buy a wheel drone freefly tero wich cost 5000 bucks :lol:
But selling a plate and a vibration isolation system at 4000 bucks is a joke for me, the base is clearly a HPI Baja 5B flux, and it has not escaped to me!
So I decided to build it myself for less than 1000 bucks
I bought a used baja 5B with spare parts and some carbon options for 290 dollars. It seemed to be a very good opportunity on the spot:
I want to convert it to brushless, I'll take this 12s esc :
he 120a 12s max
I hesitate between two 110 dollars motors :
I need to be able to take a load (camera+gyro-stabilized camera gimbal) from 2 to 8 kilos, which one would you take?
Knowing that I want my investment stay "reasonable" what do you think of my combo? Do you have other suggestions?
I know the freefly tero lift 8 kilos with the castle creation combo for Hpi Baja 5B Flux, so normally it should go without problems with an engine less powerful (5,500 watts) but with 4 lipo cells more.
Let's start the work! I have done it all in a day work yesterday.
Apparently the previous owner wanted to "lighten the chassis to make it go faster" so I'll use the other one.
In the future I'll make cut cnc additional parts in carbon plates, but for now I use a cutting board ...
It's amazing what you can do with a cutting board right?
little test to make sure everything is aligned
Preparing the frame and vibration suppression system to be painted
The bottom right triangle of the front axle is a little bit fiddlesticked up...
Metallic paint is done !
I plan to keep the disc brake with using the esc because apparently I have to choose between brakes or reverse ...
[url]http://yannkibongui.com/tarmac/conception/12.jpeg[/url] [/ img]
Put it all together!
[ATTACH=full]42176[/ATTACH]
little carbon options are nice
[ATTACH=full]42177[/ATTACH]
The HPI Baja 5B "Tarmac" next to my first car RC wich is over 20 years old
[ATTACH=full]42178[/ATTACH]
Well, it only remains to put the engine and electronic :
[ATTACH=full]42179[/ATTACH]
[ATTACH=full]42180[/ATTACH]
I want to add position lights, turn lights, and a stop light. I will be driving in FPV so there will be a camera on the front, and a rear view camera, I'll have the two images simultaneously on the video screen on my radio.
I'll put an OSD and a GPS module to have on my screen, the level of lipos, my current speed, distance etc, like on my drone.
Who says FPV says long range remote control, so I leave the original radio for a "Real" radio wich work up to 1.5 km, and it will allow me to make mixes for the throttle esc on the same pod as the mechanical brake and the second pod for reverse, my buttons to manage different lighting and control the camera+gimbal when I operate alone without camera operator.
Because of the camera mounting plate I won't be able to use the original body of 5B. I have to find a body when I'm not shooting but just want to have fun without dismantling the whole system. Which body would you use ?
That's it ! I welcome any feedback or advice!
he 120a 12s max
