HPI Baja 5B tutorials and how-to's
WoodiE
Kind of good admin.
Administrator
Kentucky
Here is a collection of HPI Baja 5b tutorials and how-to's, as we receive more we'll add it to this thread. You can also find these tutorials in our Articles link menu found above between the Gallery and Search links!
HPI Baja Checklist
Cleaning the Baja 5b pull start
Baja Brake Maintenance
More horsepower using the stock exhaust
Removing the Baja differential
Turtle Racing Diff Housing Installation Tutorial
Upgrade Baja Servos
++ Modifications ++
Throttle Brake Modification
Boot Modifications
If you find these useful then please be sure to check out our sponsors found both in the article and in the right side of the forum. If you have a part or model you'd like to review or a tutorial/ how-to and have added to our Articles page please send them contact a member of the LSF staff.
Thank you and Enjoy!
Yamadude
S.E Michigan
Just a comment on the diff tutorial.Why not mention the extra bearing hop up while your in there(B089)to replace the plastic shim on the drive gear shaft.
FastEddy
LSF Vendor!
LSF vendor
Sonoma County CA
I thought about that but decided to save it for an upcoming tutorial about how to Beef up the ass end to handle more powerful engine setups.
I didnt want to get to advanced and wonder from the stock setup on this one.
Jeremy1976
Wisconsin
What would be cool now is a how to or tutorial to take everything off the chassis the simplest way and put on another (black) chassis. Hint hint..
Jeremy1976
Wisconsin
Yeah I am getting the black chassis and want to pull everything off the stocker the easiest way possible and get it on the new one. I will figure it out I have torn tons of R/C's apart already and rebuilt them. Plus from what I see on the internet the manual for the Baja looks pretty nice.
Yamadude
S.E Michigan
And everything is bigger thats helps more than you know..Your gona love it.So much nicer to work on..
FastEddy
LSF Vendor!
LSF vendor
Sonoma County CA
I do have to say, wrenching on the Baja is a joy. I was doing this diff how to then needed to rebuild my Min-Z for our last points race this Wednesday. LMAO!! From fixing a lawn mower to making a watch.
FastEddy
LSF Vendor!
LSF vendor
Sonoma County CA
Glad people are finding them useful.
The tutorials are designed not only for the new folks but as a refresher for the old hands as well. Im a photo kind of guy myself and like to see lots of them. You can also use them to help others by pointing them to a particular photo when answering a question.
I have several more in the works. Let me know if there are any others that I should look at doing.
Upcoming tutorials:
Installing after-market radio equipment.
Installing a new battery.
Replacing the wheel bearings front and rear.
Replacing stock drive shafts.
Shock maintenance and repair.
Replacing the spur gear.
Clutch replacement and repair
Beefing up the ass end to handle more powerful mills.
Later on...
Removing the engine.
Installing a head kit.
FastEddy
LSF Vendor!
LSF vendor
Sonoma County CA
What news about news tuto ?
thank
Bertrand
I have a few in the works right now. They take a while. When new parts come in I shoot the install then write them up as I find time.
Props goes out to Eddy. I used all your tutorials and they were great man! Thanks so much for taking the time to do this for us!!!
Im sure you will be making some of your own in no time at all. Feel free to join the fun and share your knowledge with the world.
Im glad you found them useful. :)
Timmahh
Bajastafarian Madnes
PLUS member
Michigan
i ll have one later on Modding your toasted diff for a Locker. wont be testing until tomorrow though. it almost 11pm and its cloudy and dark out.
ok i wont, it failed pretty quick like.. lol
csp1971
Missouri
FastEddy-
The diff tutorial was excellent! I finally decided to take mine apart and check to see if the diff was filled with oil. It actually had some in it, but I filled it up with 7k to top it off. I'm glad you took the time to put it out there, very easy to follow.
csp
gazzarose
South Wales
Hi Guys,
Got Baja clone a few months ago, but only used it a few times, but as resonably impressed with it. Only things that are letting it down are low down power, and the brakes. Both of which you've got a tutorial for. RE the stock exhaust mod, how much louder does it make it? As thats my only concern. Would it still work if I remove the baffling, but leave the stinger on?
Also RE the brakes, mine don't seem to work at all, so I will be following your tutorial to rebuld them to see if that helps. My clone has got cheap servos in it, I don't know if the brake servo is man enough to do the job. How much torque does it need to have, or is it more down the setup of the brakes.
Cheers
Gazza
