Hydraulic brake master cyliner mounting...
moliver
Reading the Rules!
Chicago
I have a leopard with hydraulic brakes...well almost, the master cyliners need to be mounted....aside from designing my own brackets are there any avaliable for purchase? Looking for new, but used are OK.
I got a hold of KP and they are now just doing bike parts...seems like aftermarket Leopard parts are scarce....
Thanks for any help.
Mike
you needed to buy the mounting pedestal for them.
but none available for leopard cars,not nesserary either,but if you wanted to use this one in the link,it would just require a few new chassis holes drilled which is a 5min job..........
http://www.rc-car-online-shop.de/cg...m=y0989&file=&gesamt_zeilen=0Tsuche--pedestal
but if you want my opinin and it is what im going to do when i get my set of front hydros for my beetle as i have already mounted the rears (fg beetle rebuild) dc2 man,my point is you don't need any mounting bracket/pedestal,just sit the cylinder on the chassis and mark the holes someway,drill your chassis to the exact screw points and just mount it up that way.
its perfect.......and the way im going to do the next set i will be mounting.
dc2 mAN
Have you KP brake? if so you can buy a KP radio tray...or make one your self, then use some alloy tube to raise the master cylinder in line with your servos...
Hope this helped mate.
Can find you the radio tray, if you need.
