Jet pro rampage pipe
dboozer
Indiana
Myself amongst many others have had problems with the bottom of the pipe cracking, or tearing completely off where it mounts to the bracket. I just received an updated pipe with new mounting tabs to try out and see how it works. I will try and post up some pics tonight, The mounting tab on the pipe itself has been changed slightly, Also reinforced better. Hopefully this will be the solution to this issue. Because it is an awesome pipe, makes really good power and revs hard.
jetpro picshere are a few pics
/monthly_2009_05/100_1456.jpg.b74317f3e7fe7a6d9ccf3f3d09a3a26d.jpg
/monthly_2009_05/100_1457.jpg.05fe4c405f76c66fe15cf4172423d17f.jpg
/monthly_2009_05/100_1458.jpg.3a1ae151b271443e7849573013a188b6.jpg
/monthly_2009_05/100_1459.jpg.8cfdf33c3b48b84b484849821e9a946b.jpg
This is my set-up, as you can see the pipe is on the right side of the truck and the fuel tank is on the opposite direction, the tune pipe is a JetPro twin bleed from a BAJA 5B. I just cut the end of the pipe, turn it one third of a turn and reweld it. I have also made a bracket from aluminium with a rubber bushing... so far it's perfect, time will tellThe bottom torque and the sound of this thing with both end oppen its simply awsomme !!!
/monthly_2009_05/Tune1s.jpg.b7eabc4149f6078255c713a2b5eda203.jpg
/monthly_2009_05/Tune2s.JPG.6792981c1b569a812a947fb44d8bc18a.JPG
/monthly_2009_05/Tune4s.JPG.c193efa57bcbea2384644f91cbd60e59.JPG
/monthly_2009_05/Tune7s.jpg.115ae73abc166048161772c2ca225fc4.jpg
/monthly_2009_05/Tune8s.JPG.5c6e29b17ae571f3552ca8e812154d89.JPG
Lumax, have you change the tank around? or it came this way ..
lumax said:
I change it, the tank fit in both direction
Thank u Lu,,, I didn't know that... I will switch them around. It will be easier the fill the tanks..
