Killer bee kill switch....
Discussion in 'Redcat Racing Rampage' started by Vtx_f, Jan 5, 2012.
  1. Vtx_f
    Vtx_f Well-Known Member
    Jan 3, 2012
    72
    0
    Chicago area
    I recently bought the MT V3 :D and installed a CPI tuned pipe and swapped the electronics. Now to the kill switch, I got the killer bee but i'm not sure how I can make this fit in the receiver/battery box. There in no room! Does anyone have a solution for this issue. I've been online trying to find an additional box the right size that I can add along side the factory one and haven't had any luck...: I appreciate any help!
  2. whittron
    whittron Well-Known Member
    Feb 18, 2011
    190
    0
    michigan
    You could buy a Life battery,they are a bit smaller tghen the hump packs and you can get a decent one for about $20,they last l;onger then the hump packs and will give you more room.
  3. cordy
    cordy Well-Known Member
    Jun 11, 2010
    391
    0
    suburbs of chicago
    Go to radioshack ,get a plastic project box(3x2x1)catalog #270-1801. Doublesided tape it to the stock radio box and put your kill switch in there. Done my neutech that way.You will have to drill a small hole in your radio boxes to pass the wire that goes to the reciever.
    #3 cordy, Jan 6, 2012
  4. Vtx_f
    Jan 3, 2012
    72
    0
    Chicago area
    Thanks guys, love this site you guys are a great help!!!!
  5. Vtx_f
    Jan 3, 2012
    72
    0
    Chicago area
    Cordy that worked perfectly!!!!!!!
  6. cordy
    Jun 11, 2010
    391
    0
    suburbs of chicago
    Glad I was helpful.
  7. rcspeedmart
    rcspeedmart Well-Known Member
    Sep 5, 2011
    1,015
    2
    Atlanta, GA
    1+ on that they are the best!!!!!!!!!!!!!!!
  8. first25q
    first25q New Member
    Apr 5, 2018
    2
    0
    What radio do I need to use a Killer Bee kill switch. I have the MT and DR. For just playing. Thanks
  9. CBirnley
    CBirnley New Member
    Feb 11, 2017
    4
    0
    Visit their website and it will tell you what receivers they are compatible w, which will give you an idea on radios. Be for-warned, the choices of radios are fairly dated. Killer Bee has done a poor job of updating their technology to work w newer transmitters.
  10. Whoduh
    Whoduh Well-Known Member
    Mar 25, 2014
    356
    75
    Fairfax, VA
    It will work with almost any radio. This is from their website.
    • The Super Bee is 4 kill switch versions in one. No need for multiple versions for different radios. Just flip the dip switches to change how the Super Bee functions. The Super Bee works with most 2, 3, 4+ channel AM,FM, 2.4ghz radios
    • Compatible with 4 to 9v rx battery (2S LiPo compatible)
    • Adjustable low battery voltage cutoff: Choose from 3, 4, 5, 6v cutoff (great for LiFe or LiPo packs)
    https://www.killerrc.com/collections/kill-switches/products/super-bee-kill-switch-car-kit
    WoodiE likes this.
  11. CBirnley
    CBirnley New Member
    Feb 11, 2017
    4
    0
    Define “work”.
    If you want it to just work like a failsafe and return your controls to neutral then yes, it works w most Rxs.
    If you want it to shut off your motor, as it is advertised, then no it does not work w all Rxs.
  12. Relic-1
    Relic-1 Member
    Mar 19, 2018
    23
    0
    So I've got the thing installed , still waiting for receiver , I'm working on a vekta , the tiny circuit board , where is everybody putting that , and does this plastic tuff come off the circuit board , haven't figgered that parts out yet ,
  13. CBirnley
    CBirnley New Member
    Feb 11, 2017
    4
    0
    I was able to place the board inside of my battery/receiver tray. As for the plastic, I believe it is to be left on, at least I did.
  14. Iceman2733
    Iceman2733 Active Member
    Feb 10, 2018
    25
    0
    I fit mine also in the battery box with DDM 7000mah 2s and my futaba rec it was very snug.
    Plastic cover does stay on it
    #14 Iceman2733, Apr 17, 2018
