i have the king motor t1000..it has the 2 speed gearing and the 30.5cc motor..i have beat the thing and have broke parts(i wreck hard,so they should have broke,my fault:lolbut overall the truck is sweet and fast,and in my opion well worth the money.as with engine problems that could be with any 1/5 scale..mine is very good and runs strong..im going to buy the baja buggy next.. i am very happy with my king motor,hope this helps my friendHi, I am looking into 1/5 Baja gas. I have considered the King Motors 5B, Rovan 5b, and FS 5b. Which out of these are the most reliable? I heard King Motors has engine problems and the metal is not good. Otherwise, the King Motors is good?
+1 i agree also km is way better imoKM is better than Rovan
I couldn't even get mine to fire up right out of the box the pull start pawl was broken.+1 i agree also km is way better imo
Thanks for the input. I'm hoping for the best. I live off grid basically and it takes me 1.5 hours to get to a hobby shop but I'm going tomorrow and see if they are open I can get some diff oil and a new pawl or complete pull start if they are open. As for Dan he so far has been great so I'm sure he will probably send me a new one and thanks again I feel somewhat better.No you didn't mess up, we have all had these growing pains, get a metal pawl for the pull starter,reset your needles to factory settings, sometimes they come way off from the factory and try again and see if it starts. The pipe, well sooner or later it gets a little ugly, but you wont be looking at the pipe when you run the truck, so that's just a cosmetic thing, or just polish it. Maybe the truck was sitting around for awhile. Dan is a very good guy, he'll get back to you and make it right. For know, take the truck apart from front to rear, check oil levels in all 3 diffs and shocks, Loctite all metal to metal fasteners, that's half the battle and required for all 5t scales, don't give up, keep at it, and when you get stuck, lots of guys here have the same model and can help you out. Go get em.
That looks like it was returned, and resold.View attachment 11098 View attachment 11099 View attachment 11100 Ok I just joined and I am new to 1/5 scale as I have never even had one running in front of my eyes. I don't have a big budget so after reading some of the blogs and vlogs I opted in for a king motor X2. Dan was great through the order and the delivery was great so the unboxing...... rusty exhaust pipe, rusty throttle linkage, some brown goo in the middle of the chassis, little specs of oil all over. So that being said I charged the battery and put batteries in the remote and got my mixed gas ready and here we go I primed the carb and screwed the idle screw in and pulled the starter and it rolled maybe 1.5 times and it would not return so I pulled the starter off and the pawl is broken. So can any body tell me I messed up buying this thing or is this normal? A thousand bucks and can't run the thing I'm very far away from a hobby shop and I have e-mailed Dan with no replies yet. Has anyone had these issues and explain what this is? Thanks for any help.
