Well see if you can solder new wires on it mate
I may just try a bit of fuel line in there, not sure if it will work but got enough time to see?I was going to say that they were referred as shoulder screws or bolts ,you can also use fuel tubing to shim
your brake plates ,it keep them from binding!
I don't use the tubing on my Baja ,but I use the silicone tubing on my nitro brake.I cut the right length to go
between the plates ,just enough to keep the plates from rubbing the disk when the brakes are not engaged ,
the tubing is soft an will squish down when the brakes are applied!...
I have never had to replace a pullstart. Hope I didn't just jinx myself?Pull starters die at an amazing rate. I bought so many,
I have backups to backups and then some more.
yyyhjju?I have never had to replace a pullstart. Hope I didn't just jinx myself?
Well.... You must have be be a gentle puller...?I have never had to replace a pullstart. Hope I didn't just jinx myself?
