KM Baja 2.0
well first ,check diff oil,shock oil and fittings, check all the nuts and bolts are secure, oil air filter,
second before or after break in change spark plug
optional change carb, servo's, radio gear
and finally before you go all out buck wild get a kill switch.
don't want it to depart you so soon,
i'm sure there are few things i'm forgetting, but others will post other items i'm sure need to be replaced
good luck and have fun
I bought the same car from them over a year ago, you'll need to replace the Pull Start and Servos, they are crap and will give up soon enough. A KillerBee switch should be on top of your list as a run away will destroy your purchase in 10mins....lots of mods out there to do yourself to keep costs down such as Stockings for outwears and do you own window sets... the shocks are 4mm so when they go swap to the 6mm..i'd do the Bolt mod on the Pinion gear too as if it snaps you'll struggle to get the snapped part out of the clutch bell otherwise..
This is tooooo weird! I HAVE to agree with our Welsh freind AGAIN!!!!!:rolleyes:
Make sure you get the Kill-switch as a first purchase though,I didn't and a stock servo froze on full throttle........you know the rest:(
J.
KILLER BEE switch is #1. turtle racing clutch, servos, radio, exhaust, all pre filters. Turtle clutch is such an amazing mod.
This gets better and better lol
Got too spice the forum up again with some friendly banter..sorry for hijacking your thread Gary..
You may want to get some Killer rc Shock limiters too as they will help with stopping your shocks from over extending and breaking the end off your shocks..well worth the money imo..
