km baja stop pulling???
check the spur gear, pinnion gear, clutch, clutch spring, dogbones, drive cups, there is many thing it could be.............Just got to start with the easiest and start eliminating.
Just running my km banana buggy and it stops pulling.any ideas before I start tearing the differential apart?thanks
No grub screws on the baja mate..
Also check to see if the wheel hex hasn't rounded..pinion gear bolt might have snapped also, take the gear cover off and check spur, pinion and clutch for damage..
Ok thanks.the clutch bell spins freely. Kinda makes me think a spring might have broke.when its at idle it just spins.
