avconslt
Hi Guys,
I just bought an E-Converted Baja T1000 from DanLC4, a Pro Seller on RCU, and boy is it nice! Dan used a Fine Design e-conversion and installed a Neu 2215 2Y motor (750KV)! Once I got it, I installed a Castle Creations Hydra HV240 that had been converted with two heatsinks glued on the pipes with thermal epoxy, which makes it a land version! I then installed a set of Integy front brakes, with Python brake cable upgrade, and a set of KM alloy upgrades, a Hi-Tech 7955 high torque servo for the brakes, and a 4 1/2" X 4 1/2" 48V cooling fan to make sure that the ESC and motor keeps nice and cool! I have also installed a pair of Kong Power 6S 22.2V 25C 5000MAH batteries in series for 44.4V! On 12S I have been advised that it will be insanely fast, so I dialed the throttle down to 66%! I have also intalled a wheelie bar from Team Go-Nads to help keep the nose down until we figure out how to control all of that power! According to Dan and Chris over at Fine Design it should be capable of speeds over 70 MPH!! That ought to be a sight to see, if we can keep it on the road! I will also be mounting a set of Proline Bow-Tie tires and Desperado wheels, with the alloy beadlocks! Haven't run it outside yet only bench tested it! I am still waiting on some Axial Velcro battery straps to show up and I will be ready to run it! I have attached some photos of it!
Richard
Richard
