Km Rebuild
OuttaLuck
When you buy new from off the shelf its best to pull it down and rebuild,
Because most of the time its only slapped together :mad:
So why i was rebuilding i thought why not add a few uprades and mods
Two speed transmission, Port and polish inlet outlet,
10mm exhaust heat sink (Reduces heat to eng head)
998 Walbro carb with built in fuel pump (Gr8 throttle response)
NGK spark plug, Front and rear swaybar set (Great Handling)
Added two springs to rear brake, (reduces drag and wear to disc pads)
Two speed transmission silky smooth :)
if ya really wanted to do a better brake setup, get the TR 1 piece from Tulare off ebay, it replaces the lil plastic slide in piece on backplate and also the brake thingy where the pins go thru for pads. and adds a 4th mount spot to assembly. pretty much bulletproofing the brake system
