King Motor x2 build thread
95F1CF7E-0D9E-46CD-8A0E-7EB35B82F3F0.jpegB4A5D21F-B455-4680-99B3-644E536EFAB7.jpeg482000A9-4FF4-4DA7-8E10-C1B096E0A878.jpeg
Couldn’t get the spacers to fit in anyway, ended up taking the advice and just loctited them in there. Just got to come up with some spacers for the d845 to use as steering. As for the brake cams what way do they sit in the neutral position?
What pinion tooth count you using? Brake cam should be pointing slightly to the throttle/brake servo in neutral position. Just have to think about which way the servo linkage will be pulling the cams when brakes are applied.
4535FFFC-99C9-4E6C-836B-E5996EAF441C.jpeg4F204F88-B0B8-4869-A9EF-7A4DFA7520B7.jpeg686208B6-0E04-4B3E-9D3B-9A73CD1D15DD.jpeg742A7245-43C8-4C36-9E31-54D0FC843D4D.jpeg38600624-722E-476B-A682-E72563477BF7.jpeg
little bit of an update been busy recently, so haven’t had a lot of time. Dominator exhaust now on, 1st time I’ve sprayed a lexan body not too bad but it’s gonna be a basher anyway, swapped the servos over. Postman bought a 3pv as it will be more than sufficient for what I need. All that’s left is to set the linkages up properly, bind and set the end points and finally get it out for the first time??
So all up and running, haven’t taken it out properly yet. Ran in to an issue where steering servo end points just left at 100% at the moment. But when turning right it’s fine, whereas turning left it doesn’t give as much lock. Had a look it’s not hitting or catching anywhere. Anyone come across this problem before?
