rcplayground
- Reaction score
- 0
Has anybody made windows out of lexan for their DR?
Can't wait to see emlaxbro19 said:I looked online and found that all you need is lexan, cable clamps and screws so I went to Lowe's and picked everything up. Will be starting on making my own this weekend
They are coaxial cable clamps. They are pretty common. You should be able to find them.Where did you get the clamps?What are they sold as?
I haven't seen em here in Aus
Thanks mateRCDAD said:They are coaxial cable clamps. They are pretty common. You should be able to find them.![]()
Thanks Laxbrolaxbro19 said:Thanks for all the comments guys! They were really easy to do and I think anybody out there with a dr should do them on their own.Phill, just do a google search of cable clamps and you should be able to find them. I found mine at the local hardware store right next to the cable ties
I used a jigsaw with a metal blade and took a file and 420 grit sandpaper to clean up the edgesPhill said:Thanks LaxbroWhat did you use to cut the Lexan?
You got a nice edge there or did you touch it up with a file?
Normally both sides.Phill said:Thanks mateJust wondering do the clamps have tabs on both sides or just one?
