Well I wont use one heres why?With all the big bores,reeds,pipes,ect that are out there for these motors is less cooling worth the HP or a slightly higher spool up??To me no I have read up on the flywheel deal though the Baja Forum and a couple of others including the Go ped and boat forums.To me is just does'nt seem like it would be worth it.There is a good raise in engine temps although the temp differences were all over the place all of them were higher and more heat =less HP so wheres the gain in that???I maybe wrong but thats my thoughts on the flywheel.
Thats good to hear the only experience I have had with them is from reading others posts and the results were all over the place.Some said the temps go up as high as 50deg and some said no gains in temp.No one with a Baja could provide any results for me to judge.I have one and it does not run hot at all. My cousin actually put his on a lathe and machined all the fins off. That did not even cause it to overheat and he did it in the middle of summer and ran it like that for months and is still using it. Just my thoughts
Did you notice any performace gain at all???And did you check the engine temps with a temp meter of some sort??
