A piece of fuel tube inside the shock on the shaft works well.krebidoux said:you can take your shocks apart and put spacers inside to lower your suspension.
Does the chassis not have the tabs? The set screws are on the bottom of the arms.Knuckles said:They are not on the 7075 chassis though, found shock a little longer on Obeast build and without limit straps suspension droops to far and binds
With those huge shocks, your dealing with gallons of it.Knuckles said:7075 chassis does not have tabs. Actually have shocks apart putting spacers as we write, hate shock oil.
i use fuel tube for onroad and 1/10 scale.RCDAD said:A piece of fuel tube inside the shock on the shaft works well.
