RC RT
- San Ramon Ca.
Hi all
My 5t 2.0
This is a great 1/5 scale first and formost
but I have had couple issue's
Break in was done with 25/1 ratio,
Broke motor in using heat and cool method 1st.
first start up ran for 5 minutes let cool for 30 (motor never got over 140 degrees f. at little over idle
second start, ran about 10 minutes let cool 30 little higher RPM
third start ran for rest of tank out at about 1/4 throttle
First field trip, found a field with dirt and low grass (throttle was 75% max available
fired it and ran for about 5 minutes and motor locked up, found that clutch shoe bolt had came loose and locked up clutch
pulled both bolts and used blue Loctite ensuring only on threads (none on shoulder of screws
Next run found a empty parking lot and ran about 1/2 of a tank with 100% throttle available nice run, but oil on chassie from pipe exhaust
next time I went out wasn't able to start, coil needed replaced.
Well I just finished reworking pipe everything looks good, added 2.125" to outlet of exhaust and little twisting of mount bracket on pipe
Upgrades so far equal
Bartalone Big Bore Silenced pipe
Super Bee Kill Switch w/buzzer and led light
pull start outer wear
cooling fan outer wear
My 5t 2.0
