Kevin Cabral
- Reaction score
- 3
Hey everyone,
I so far ran 2 full tanks of gas through the engine. I bought the truck brand new 2 weeks ago. One thing that has bothered me by the truck is the stock shocks. They don't rebound quick enough. The rear shocks sort of sit a bit lower than the front shocks. I assume it's due to the weight of the engine. Yesterday I tore up a baseball diamond, it was a lot of fun! However, it made a huge mess to the truck
. So I removed the center diff for cleaning and also removed the shocks for cleaning. That's when I noticed the ball joint had some shock oil. After checking the shock boots for cracks, only ones I saw was where the shock cupping is located. It seems the shock cupping cuts into the rubber, making a hole into it. So each time I run the truck, sand, dust sticks to the ball joint area if the shock oil leaks. It seems the rubber material used for the shock boots, are not thick enough to withstand a beating. I've seen shock wraps at my local hobby shop. Are people using these instead of the shock boots? It looks like these shock wrapping is a way better option. It covers the entire shock.
If anyone has suggestions which shock wrapping to go with, please let me know. Also, I will eventually buy new shocks, the stock Losi shocks seem very sluggish to me. Any help would be greatly appreciated.
