Hi guys,
im having troubles with a km 30.5cc. After replacing a bad leaking manifold, the engine bogs really bad on the low end. Acelerates very slow, and if a pull all the ways on the gas, it wants to shut down. Only if i gas very slow, i can be able to pass to the high end. The high end seems ok. I changed the carburetor with an original walbro 668, and improved just a little, but the bog is still there. I also tried to adjust the low end needle, tried rich, a little lean, but didnt fix the problem. What could it be?
