LS with the biggest ground clearance?
adr_ian
Sweden
which large scale truck has the biggest ground clearance on the market?
i saw that the rampage mt has 70mm but that kind of small clearance for such a big truck :(
It depends on Tier and spring shocks. But if I remember correctly its 70 plus or mines. If you go moor it will roll vary easily? For sand and asphalt it had been fine with me.
Are you after just stationary ground clearance, or are you more after suspension travel? Some of the trucks out there just have huge tires but they don't have a whole lot of suspension travel. The Baja sits relatively low, but has a lot of travel, so from full droop to full compression, I would say the Baja is hard to beat at the moment.
i would like to have as much stationary ground clearance as possible, its not gonna be a race car :-)
redcat rampage mt has 210mm tyres and only 70mm g.c. :(
i think the ground clearance should not be less than half the tyre size...
