Porschester
Hey guys,
Just got my Marder up and running properly and I was wondering if I could get some handling advice. Basically ..
1. How should I set my adjustable diff? tight or loose? I'm thinking the looser the dirt is the looser the diff has to be .. reason being is that its quite tight and in the freezing conditions i'm almost uncintrollable, constant spin outs when I hit the throttle.
2. I have some front cable disk brakes and a standard single rear disk. When I brake on a corner the car is kind of pushing through the corner and not turning agressive enough .. how should I adjust these brakes? more 'braking' on the front or rear? whats good practice?
3. One more, How to get more turning authority at speed and when slow?, ok so i will back off the tight diff a bit but do i need to tighten up the steering servo saver? or add weight to the front? I really want the front to bite into the turn a bit more. Maybe some bigger tyres? any recommendations?
Any ideas would be great .. or if anyone knows of a thread that discusses this that would be great too.
Thanks
Porschester
Thanks
Porschester
