so is here. I cannot describe how huge and heavy this motor is. Same goes to the esc.
Motor is 70mm/125
Little challenge installing the motor. It was hitting the chassis so I had to raise the tranny/motor 3.65mm to get everything sorted out and enough room for chassis flex also.
It is absolutely super sturdy with 5 bolting points. On the other hand vitavon will be coming out next week with the correct mount and I will switch it out.
Might pick up the 7mm chassis also from them.
Got 2x 6S 9500cnhl on order running 12S. Max pinion size is 25 with this motor mount but I am sure the new mount will go higher.
Took the cover off the max4 to install mesh screen.
Motor is 70mm/125
