MCD Hydrax Servo Setup Help
zxb466
LSF Plus Member
PLUS member
Los Angeles, California
Can anyone please help give me guidance on how to setup two servos to for the hydrax brakes to work together?
I am using a Y splitter harness on channel 3 with both servos working in the same direction. I need one of the servos to work in the opposite direction. When I flip the connector one of the servos stops working completely instead of reversing.
They are AGFRC servos and am using an Futaba 10px transmitter.
I did not use the reverse feature on the transmitter because then both of the servos reverse.
For a front / rear hydrax setup do I need to use a separate channel for each servo? Any advice will be appreciated. Thank you!
Ok I think I figured it out. I used a Y harness on channel 2 with throttle and front brakes; and the rear brake servo alone on channel 3. Seems to be working fine. Let me know if anyone has it setup differently.
That's how I would do it too. You are probably already aware of this, but you will want to setup your front/rear brake mix too.
I don't have the hydrax kit yet but might get it later.
