mcdracerunner
right lads got an evo 3 and also got an lsd for the front now when i have gone to fit it the diff output shafts are longer causing the drive shafts to be very very tight in the cups no movement at all i have had the diffs next to each other and the new lsd is about 1.5mm longer on each end has anybody fitted a lsd and had the same problem
here is a pic of the std diff smaller one and the lsd
