MCD Truck info needed...
ChopChop
Pakenham
Hey all, ive just come over from a Baja5b and have a new MCD Truck on the way.
Anyway me question is what needs doing to a Proline MCD MT?
I have the radio gear and ordered a blinged up 30.5 engine and 3x hitec MG servos and an RX Pack. I saw somthing about steel gears?
Any advice would be great....
Steel gears are also available in 24 and 25 teeth, remember the Alloy Gear-plate........You will need it sooner or later.....
hi to all, anybody knows where can i find the manual for mcd monster truck? i just bought a used one and it doesn't come with the instruction manual,thanks again.
Steel gears 23/26
Servo tray, aluminum one
Tank supports I made these, but MCD makes them too.
If it EVO III make sure you have a spare set of lower controll arms, and also make sure the droop setting grub screws are set properly.
Rear bumper I made to protect my JP pipe
more aluminum
Vertigo aluminum gear plate, damn he makes some beautiful stuff
a set of rubber sealed ball bearings for the MCD's the ones in the MCD's are metal shielded and require some cleaning and re lubbing
Another Vertigo part, centre gear carriers
Not all nescessary but over time I'm sure you'll have it all done. lol
