MONAROMAN
- Sydney Australia
Just putting together my racerunner and have stumbled on the servos slightly, considering you cannot flip the location of the servo and they must rotate in opposing directions, what is everyone else running to control steering - a Y harness with signal reverser for one servo, channel mixing on an aux channel or a digital servos with one programmed to rotate in reverse?
I was going to run 2 x HS755MG's but they can't be reversed without soldering (I am not opposed to this - just can't get the darn servo apart fully! :hammer
or I can run 2 x HS5745MG digitals but have no access to a programmer to set it up.
I do have a spektrum DX3.0 radio and can setup the channel mixing but when it comes to epa and trim adjustments they have to be made individually, ie if I want to adjust my steering as its not straight I will have to adjust both the steering trim and aux channel trim to exactly the same point to stop servo's fighting against each other... this I can see will be a pain. Or am I just not using the radio correctly?:helpsmilie:
