So I have to drill in the chassis first?You only need two holes offset from each other, like caddy corner.
Yes you do, find the correct size screws for the master cylinder and drill two holes from the top. Then countersink the holes from the bottom. I can show you pics of mine when I get home later.So I have to drill in the chassis first?
Please do and thanks for the help!Yes you do, find the correct size screws for the master cylinder and drill two holes from the top. Then countersink the holes from the bottom. I can show you pics of mine when I get home later.
