Missing Bearing
FastEddy
LSF Vendor!
LSF vendor
Sonoma County CA
Page 41 of the Manual Replaces parts 86667 and 85430-4.
Goes on the spur shaft where it enters the case replacing the dust shield and retainer clip for the shield.
If you need some assistance in tearing it all down, everything is covered except the bearing upgrade in this tutorial. The upgrade tutorial is coming soon.
https://www.largescaleforums.com/hpi-baja-5b/removing-the-baja-differential/
Timmahh
Bajastafarian Madnes
PLUS member
Michigan
its the same bearing that is on the spur shaft either inside the gearcase, or at the brake assembly. its being put into the gearcase, just inside where the spur shaft enters, and replaces the rubber dirt shield.
sorry not sure of the stock item number.
in the manual you ll find it on the gear case page.
