Gaffle
- Atlanta, GA
I’m upgrading my 5T2 springs and moving the gasket ring to the inside. Is it okay to mix my Losi 90 weight oil with whatever came with the car?
Thanks for the words of wisdom. Along with the strongest silver springs, I felt 90wt. oil would prevent the truck from sagging and perhaps would lean it to do wheelies with my 65cc motor in charge. So my rear was full with stock 40wt, then I removed 5ml and added 90 wt on each rear. I'm guessing the rears are currently 70% 40wt and 30% 90wt. I used a syringe to measure those 5ml's.Just curious but why would you choose 90wt. That is extremely thick and will really negatively affect the shocks performance? Springs are for weight and landings, oil is for dampening bumps. Yes the larger Motor is heavier but I would not jump to 90wt, stock is 40wt on the Losi 5ive T 2.0. I am not saying that 90wt wont be interesting to try but I am sure you would be happier with a much lower choice. As for your original question yes you can mix oils but if you do that then you will never be able to find a repeatable setup that you like and can go back to. The shock oils are pretty cheap in comparison to the rest of the stuff we buy for these. Best to use a known variable and and log what you did so you can make changes and go back as needed.
Main goal in order by your list:The "sag"(ride height) is adjusted by the shock adjusting ring. Wheelies happen when you get traction and your suspension has reached its maximum bind, soft rear stiff front for faster weight transfer. The suspension can be tuned to do different things. What is your main goal? Handling, Jumping, Wheelies or Straight line acceleration
