Motor Install on Baja 1000
check your engine in it first what you are looking for is it to clear the shaft comfortably mine needed skimming but we had skimmed my brothers engine to find it would have fitted without the skimming probably your best bit is to skim it bit by bit not to heavy or you will go thru the crankcase u will probably have to remove the fins and skim it slightly on the opposite side from the fins followed by a half moon shape on the bits of the cast that run where the shaft is gonna pass thru its not hard to do but i will stress do take it slowly and u will be fine and weused a dremel best thing god created for us rc boys
