Got some time to remake engine mount today.Just a piece of wrecked camaro subframe,cut ,drilled and slotedholes for taylor 50.Used a set of losi 5t 2.0 engine inserts on primal crossmember to fill area for fhsh screws primal used to mount original motor.This way can use regular shcs to bolt plate to crossmember.Used same to bolt plate to taylor engine.Had to trim about 1/4 inch off taylor mounts.The 50 is now supported by like primal stock engine.Sorry I am a mekchanix not a photographer..... Brake pads are steel traced from stock primal pad.Cut,drilled ground to mimic.That is a new set of primal pads.Zero wear,works great,stops very good.Drop of super glue to hold them on to primal pads
