MT Body Dimensions
KUN114
Can someone tell me the length and width of the MT body?
I'm looking at getting a clear Firehammer MT body which is 24.75" long by
9.5" wide. I'd like to compare dimensions before ordering.
Thanks,
Jason
Sprint 77 said:
They are a little small looking on the rampage I have one. It lacks about 1.375" of having the right wheelbase look. I wish but don't waste your time.
Can I get the length in between the wheelwells on the firehammer body?
If it's a little shorter, It might work ever better than I thought. I actually want to use it on my TT with the wing and Baja wheels.
Thanks
TT body on the MTi have both but the fire hammer is too small the body pins hit the far ends of the bodyi put the rampage baja body on mine and here are the pics
/monthly_2008_11/101_2070a.jpg.4e256e9b241db2542b59bd52576cf1a2.jpg
/monthly_2008_11/101_2069a.jpg.39c691bbdb35d23cafd35a4d7302d8eb.jpg
From the look of it, it looks like it will fit just perfectly. The stock body on the MT5 looks a bit short when looking from the side. I don't know the length from wheel well to wheel well on the baja 5t body, does anyboby have the spec on this?
I'm using an MCD MT body, same as an FG MT but a little cheaper than FG's.
They fit good with a little trimming. Redcats have a club cab shortbox style compaired to these, single cab long box style so you have to trim the back of the cab a little unless you want to raise the body a little more. I also use a piece of foam from the kids water noodle ( I think thats what they call em) to give the body more support when it goes for a good tumble!
