My 5iveT v1.5 basher build thread
Frenimy
I have one and this is by far the best motor I have run. The Bartolone motors might make slightly more power but definitely don't live as long as the OBR stuff. Call them and Dan will build you anything you want. Run it with a 990 carb and an Olimat pipe for the best performance you can get. I upgraded to the ceramic bearings as they should last a couple years just like the rest of the motor.
Basher5iveT420
LSF Plus Member
PLUS member
Florida
How is the drive train holding up with this engine ??
I have a Bartalone racing tune exhaust that should work reallly good with this engine.
what’s the difference with the carbs ?? I was recommended the 990 :unsure:
Frenimy
The Drive train needs some stuff beefed up like the outdrives but those need to be beefed up even with the stock motor. The rest is doing great with the extra power. The 990 carb has crisper throttle response than the 1107 but does not have a choke. If the temp is 55 or higher not really a need for a choke as long as you prime the motor like you should. I can get mine started with out a choke when it is 40 degrees outside.
Basher5iveT420
LSF Plus Member
PLUS member
Florida
The front guards showed up today. Just waiting on the rear guards ....
I waited 7 weeks for these to show up, but only the front set arrived.
So I reached out to the seller on eBay.
Turns out they only packaged the front, so they are sending me another complete set + the rears they missed the first time....
Which is pretty awesome, these bad boys cost about $80 for the front & rear.
Awesome customer service (y)
evssv
Bristol uk
they do look awesome....:love:....but not $80 awesome....:(
Basher5iveT420
LSF Plus Member
PLUS member
Florida
Awesome rig. How do you like that intake? I’m considering that one or the crazy Stu intake.
I like the build quality of the Turtle Racing air intake, it feels super sturdy like it will last forever..
I got the one for the HPI air filter, it’s been a perfect combination thus far.
Ive never tried the CrazyStu but it looks super cool too, like a more rugged look.
You can’t go wrong with either one :cool:(y)
Basher5iveT420
LSF Plus Member
PLUS member
Florida
I upgraded ALL the shock springs.
Shock oil is 40wt all around
Front is now 14.5lbs
49584
REAR is now - 11lbs
49583
I can do a dead drop from around 24inches with zero frame slap, I just hope they aren’t to stiff now and cause poor handling.
