where is it coming from and where do you live?
Search this user on ebay ?Servos are in.... can someone tell me how to set up the servos properly. View attachment 47970View attachment 47971View attachment 47972
Also I lost this screw. where can I order it from View attachment 47973
Figure out the size and order from this guyServos are in.... can someone tell me how to set up the servos properly. View attachment 47970View attachment 47971View attachment 47972
nice ride ??I just installed the steering and throttle servos.
Also installed new fuel lines....
Took out the 5iveT at 10:45pm to test out the servos. And man it feels nice, I can’t for the new radio to arrive so I can fine tune the throttle and steering servos View attachment 47975View attachment 47976
I use the same setup and mine still leaks around the grommet. Actually its the snappy rc ultimate fuel kit with the ffrc brass fittings.Did u tube the brass hi flow fittings..as in this Imo/experaince the fittings don't make a very good seal if just pushed in.....but the tube nakes for a very tight seal...i run this on 4x of my 1/5th 's
I have the snappy kit on my baj and i find that silly breather thing leaks everywere ....but all my other 3x r fine ...i thk i will b removing the snappy crap and jus run a 2x hole grommetI use the same setup and mine still leaks around the grommet. Actually its the snappy rc ultimate fuel kit with the ffrc brass fittings.
Maybe i just need a new breather then. Do you use any kind of sealer around the grommet?I have the snappy kit on my baj and i find that silly breather thing leaks everywere ....but all my other 3x r fine ...i thk i will b removing the snappy crap and jus run a 2x hole grommet
